1. AC Question's Avatar
    AT&T just had an update (took) 4 different times for it to complete and now the battery is draining worse than it already had been (Note 5). What did they do? Everyctask now takes an extra step; for instance, when I pull down from the top to see all of my quick settings, u havexto oull down twice to see them and tgen there's another page I have ro scroll to.... That's just ONE issue. Same with dialing a contact phone number. Now there are two steps to make a call. There's more but let's just start there.
    BTW, I force many apps to close and am very conscious of closing things. I run lean....
    07-27-2017 10:28 PM
  2. chanchan05's Avatar
    Sounds like you got a major update with a bit of trouble installing. Personally I'd do a factory reset but maybe you can get away with a system cache clear.
    As for seeing all the quick settings, you can use two fingers to pull down to see everything at once. Or just rearrange it so the most used ones are the ones shown on the first pull down.
    The phone issue is just due to the new design of the dialer app.
    I'd go through the whole force closing everything is a bad idea but that's alreafy everywhere.
    07-27-2017 10:38 PM
  1. Replies: 1
    Last Post: 09-26-2017, 05:06 PM
  2. Problem with my battery
    By crammpa in forum LG K10
    Last Post: 09-26-2017, 05:05 PM
  3. Replies: 2
    Last Post: 07-28-2017, 07:51 AM
  4. Stop S7 updating dictionary of useless words
    Last Post: 07-27-2017, 11:03 PM
  5. Replies: 0
    Last Post: 07-27-2017, 10:04 PM
