1. AC Question's Avatar
    When customizing Ringtones on my s7Edge, I found old Voicemails under Sound Picker> Tracks. (Sound Picker is accessed by choosing "+" in Ringtone settings.) If I select one, it appears on my Ringtone list. I'm not finding a Delete option for either list. Help?
    08-02-2017 11:25 AM
  2. ManiacJoe's Avatar
    Most likely, to remove the VM file from your ringtone list, you will need to rename or move the VM file.
    08-02-2017 01:15 PM
  3. Susan1225's Avatar
    Go into "My Files" (Samsung folder / Apps List). You can delete the old VM's from there.
    11-05-2018 10:12 AM
  1. Not getting any image from USB Camera using CameraFi
    Last Post: 08-24-2017, 11:21 AM
  2. Can't uninstall apps
    By br3ndab in forum Ask a Question
    Last Post: 08-02-2017, 05:24 PM
  3. how do i get messages not sent off top of phone
    Last Post: 08-02-2017, 01:23 PM
  4. I can't connect my Vodafone Smart Ultra 6 to PC
    Last Post: 08-02-2017, 11:34 AM
  5. Replies: 0
    Last Post: 08-02-2017, 10:46 AM
