A
AC Question
I have an s7 edge that i got after the horrible note 7 experience. Since the last update (maybe 2 weeks ago, i cant recall) the phone will no longer aknowledge my sd card at all. Doesnt say its corrupt, doesnt say for me to insert sd card. NOTHING at all.
i do not even have any sd card settings under the setting menu. the only thing that comes up when i search in settings to encrypt the card . In camera options it doesnt even give me the ooption to switch to sd storage.
I have tried the other card in different devices and it works perfectly.
I contacted samsung support and the rep told me that its because i have a non samsung card so its incompatible with the device. mind you this is the same card ive used since i got this phone.
in addition, i can no longer get my phone to connect to my gearfit 2 once it is paired. Seems this latest update did no good with my device
Has anyone else experienced this? Solutions other than master resetting?
