1. AC Question's Avatar
    Galaxy S4 mini
    When my battery gets low, a popup notification suggests turning off the wi-fi. The problem is, this notification turns the screen on... and stays on! If it's in my pocket and I don't notice, the screen stays on full brightness, draining the battery. A bit ironic for a battery-saver notification.
    Any way to turn this off? I wouldn't care except that the screen drains the battery faster than anything useful that the notification suggests even would. I did manage to change the notice to 25 instead of 35%, so at least it has less charge left to waste. However there doesn't seem to be a "go away and don't come back" menu option.
    It does seem to be a recent update. I noticed it a couple weeks ago. Pretty sure I would have noticed it beforehand if it was happening.
    08-15-2017 01:00 AM
  2. belodion's Avatar
    🙋Is that a stock warning, or one from a third-party app?
    08-15-2017 07:26 AM
  1. How can I change Lenovo screen back to the way it was
    Last Post: 08-15-2017, 05:36 AM
  2. Replies: 2
    Last Post: 08-15-2017, 04:42 AM
  3. Replies: 1
    Last Post: 08-15-2017, 03:01 AM
  4. "Download size requires wifi" how to remove this notification
    Last Post: 08-15-2017, 01:38 AM
  5. I cannot find the location access on my imperial smart tv
    Last Post: 08-14-2017, 10:12 PM
