1. AC Question's Avatar
    Does your phone shut down below 90% battery capacity and refuse to turn on till it's plugged?
    Before buying a new battery try the steps below.
    1) Remove the battery.
    2) Drain the battery.
    3) Place battery back in phone and charge to at least 99%.
    4) Turn phone on and verify all is ok.
    5) If the steps above worked for you - remember to unplug phone when fully charged and let drain to around 15% before recharging.
    How to drain battery:
    Connect a load to the + and - of the battery. The load I used was a 5v DC cooling fan - took over 12 hours till it stopped spinning. Other load options are flashlight bulbs. If using LED bulbs do ensure correct polarity for the LED to light up.
    08-15-2017 07:34 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Thanks for the tip.
    08-15-2017 01:34 PM
  1. Replies: 1
    Last Post: 08-15-2017, 01:45 PM
  2. Samsung S7 edge battery sudden drop from 30% to 0%
    By euynnyl in forum Ask a Question
    Last Post: 08-15-2017, 07:55 AM
  3. S7 edge battery drain issue
    Last Post: 08-15-2017, 07:40 AM
  4. Battery notifications kill the battery!
    Last Post: 08-15-2017, 07:26 AM
  5. What is wrong with my phone security???
    Last Post: 08-15-2017, 04:57 AM
