A
AC Question
I was able to connect my laptop, and other mobile to my S7 Edge via mobile hotspot until I rename the SSID, but after renaming the SSID my laptop and other mobile(s) does'nt connect.
How can I get back the default SSID. I try to rename the SSID same as the previous name but no luck.
Reseting the mobile network to default doesn't help either.
Any suggestion other than reseting to the entire contents as factory default?
