1. AC Question's Avatar
    Im using a iPhone base it takes longer to charge but I have a samsung travel adapter model #EP-TA20JWE. Is their a fuse inside the charger
    08-22-2017 06:26 AM
  2. belodion's Avatar
    🙋 Someone here may happen to know that, otherwise, the manufacturer would.
    08-22-2017 09:56 AM
  3. Rukbat's Avatar
    Samsung uses a wire in the charger to indicate to the phone that it's connected to a plugged-in charger. Apple doesn't. So in the iPhone charger, the phone is charging as ig it was plugged into a computer's USB port - 450mA.
    08-22-2017 02:07 PM
  4. L0n3N1nja's Avatar
    iPhones don't support rapid charge, the Note 5 does. The Note will charge faster on a rapid charge capable charger, which the iPhone wall plug doesn't support.
    08-22-2017 03:02 PM
  1. Would a samsung evo sd card work on the HTC's Desire 510?
    Last Post: 08-22-2017, 07:36 PM
  2. Hiw can i turn ofc my screen overlay onan android
    Last Post: 08-22-2017, 07:24 PM
  3. Bad reception (Signal) compared to other phones including Galaxy S6
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 08-22-2017, 05:52 AM
  4. Replies: 0
  5. Phone not recognizing a particular set of earphones.
    Last Post: 08-22-2017, 05:11 AM
