Is it possible to check Airpod battery life on my android?
  • Start date Start date
A
AC Question
I recently purchased a set of Airpods. They paired with my phone, and seem to be functioning well, but is there a way to monitor their battery life on the phone?
BatOn did not work for me either. Use AirBtts instead. It's 1,99 unfortunately and I never buy apps normally but the reviews were positive and so I decided to download it. Fully works, displaying both AirPod's battery level and also the battery level of the case. Only downside is it shows the battery level in increments of 10%, but I tested it and it's accurate as can be. It works, so definitely worth the money for me.
I tried every app on Playstore with no luck. I saw BatOn her that Jason suggested, tried - Didn't work with Airpods.
Last week I found Droidpods app on Google play, I bought it and, viola, it WORKS, I compared to iPhone information and it's same. It shows battery info in notification area which is really good it does not covers screen, and what is good it has notifications for low battery. It works great for now.
Who want to check it out here is link of Droidpods:
https://play.google.com/store/apps/details?id=com.ctrls.alex.droidpods
Remsangpuii
