1. AC Question's Avatar
    First issue I've had with my tablet....says overheating too much to charge
    08-30-2017 04:56 AM
  2. jasonandrews25788's Avatar
    this video might help:
    however, removing the cover might not fix the problem
    08-30-2017 10:36 AM
  3. Rukbat's Avatar
    Unless you've worked on the insides of tbs before, I strongly recommend that you don't open a tab yourself. That usually results in a tab with a good battery, but many other problems. It's worth the price that a decent shop will charge you for a battery replacement.
    08-30-2017 11:46 AM
  1. Replies: 2
    Last Post: 08-30-2017, 04:44 PM
  2. Read a .txt file on Asus K013 Tablet
    Last Post: 08-30-2017, 01:58 PM
  3. Replies: 1
    Last Post: 08-30-2017, 01:14 PM
  4. how to add xtra servers in gps-configuration.?
    Last Post: 08-30-2017, 04:49 AM
  5. What does the badger app do?
    Last Post: 08-30-2017, 03:18 AM
