Is the LG3 and LG4 charge the same.
s the LG3 and LG4 charge the same. I have noticed on the android charges that I have work on a LG 3 phone. Though I ordered a LG 4 and came with the phone and now after less then a month have to position a certain way to charge. I have one other charger that works. I do not know if there is a special Charge for the LG 4 that I have to order?
Re: Is the LG3 and LG4 charge the same.
Welcome to Android Central! Any standard charger should work on both phones. If the phone or the cable has to be in a certain position to charge, then that charging cable is probably failing -- there could be a wire inside that's fraying, and causing a loose connection depending on the position.
