1. Rahman123's Avatar
    Hi Guys ,
    I am searching for a software/app, which can enable 4k resolution for video recording on my lenovo k6 power. I have downloaded the paid version of Cinema FV-5 , using that, i was enable to set resolution as 4k for vedeo recording. However, when i inspected the recorded video details, it shows recorded as 1980 (full hd). Is there any way to enable 4k recording?
    09-17-2017 05:03 AM
  2. jasonandrews25788's Avatar
    this is not possible as it needs special hardware.
    09-20-2017 05:29 PM
  3. Rukbat's Avatar
    The phone is 1080x1920 - 2k, not 4k. You'd have to find a camera that fits the camera slot, connects to the same connector, and has 4k resolution. It would be cheaper to buy a 4k phone. (BTW, there's no way to see 4k on the phone, since the display is 2k, and even on a 4k phone you can't see the difference between 2k and 4k on a 5" screen.)
    09-21-2017 01:34 PM
  4. L0n3N1nja's Avatar
    Did some digging, phone only supports 1080p video. Wondering why that is, I discovered the specs and found that the Snapdragon 430 in your phone can't handle 4k. It won't matter what software you install as the hardware can't support it.
    I would assume it doesn't support it because the processor isn't powerful enough and that's why it's limited to 1080p, can only expect so much from an entry level device.
    09-21-2017 02:48 PM
  1. Nexus 5X crashing repeatedly on Oreo
    By nomold1 in forum Nexus 5X
    Last Post: 09-26-2017, 03:12 PM
  2. My s6 has a black screen and a constant blue light on
    By Jah-jah flacko in forum Samsung Galaxy S6
    Last Post: 09-26-2017, 08:45 AM
  3. How to Root Galaxy S3
    By koolkingrichard in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 09-21-2017, 01:37 PM
  4. Replies: 1
    Last Post: 09-20-2017, 05:29 PM
  5. Any issues using the Gear 360 camera on Note 8 ?
    By tonydroid99 in forum Samsung Galaxy Note 8
    Last Post: 09-17-2017, 12:18 PM
