A
Android Central Question
When I plug the aux cable into my car stereo and turn up media volume to 100% and car stereo to Max it is still very low volume with very little bass. I'm pretty sure this has something to do with the headset icon appearing when I plug in the aux cable to my phone. My guess is the volume and bass are limited for safety and possibly quality reasons. Is there a way to tell my phone it's an auction cord and not a headset? I tried using the Dolby eq to boost it and it helped but not enough. I tried 3rd party eq and app specific embedded eq's. No luck with those. I'm using SoundCloud but have verified the problem is global. If the phone is just unable to overcome this issue, can someone recommend a better phone? The zmax is a pile of garbage anyway so I will be getting a new phone asap.
Thanks for any help.
