    When I plug the aux cable into my car stereo and turn up media volume to 100% and car stereo to Max it is still very low volume with very little bass. I'm pretty sure this has something to do with the headset icon appearing when I plug in the aux cable to my phone. My guess is the volume and bass are limited for safety and possibly quality reasons. Is there a way to tell my phone it's an auction cord and not a headset? I tried using the Dolby eq to boost it and it helped but not enough. I tried 3rd party eq and app specific embedded eq's. No luck with those. I'm using SoundCloud but have verified the problem is global. If the phone is just unable to overcome this issue, can someone recommend a better phone? The zmax is a pile of garbage anyway so I will be getting a new phone asap.
    Thanks for any help.
    10-03-2017 04:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you tried turning off all equalizers? I've found that most equalizer settings actually cause the overall volume to go down.
    10-04-2017 05:21 PM
  3. Crypto Thick's Avatar
    Yeah, I have turned eq off. Almost certain this is a limit because it thinks headphones are in. There doesn't seem to be a way to tell it that it's aux and not headset. I think the only solution is a different phone
    . Eff ZTE anyway,. Total crap
    10-04-2017 06:25 PM
  1. "In-Call Volume" issue
    By b.grdner in forum Samsung Galaxy Note 8
    Last Post: 09-02-2019, 08:02 AM
  2. Very low sound out of left ear bud
    By Paul5190 in forum Samsung Galaxy S8 & S8+
    Last Post: 10-02-2017, 07:41 PM
  3. Very low sound out of left ear bud
    By Paul5190 in forum Ask a Question
    Last Post: 10-02-2017, 11:50 AM
  4. volume call problem on Samsung S8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 10-02-2017, 07:32 AM
  5. volume call problem on Samsung S8
