    Yesterday i have reset my Gionee P5L and after resetting i have turned on data , though it is showing as its turned on when i open Google or some other apps its showing to turn on data. And the jio4g voice in my notification bar shows it was offline. Please help me. I have restarted my device and also turned it off still the problem exits. What i have to do to fix it..? Please help me. It have been three months that i bought my mobile and sim.
    10-04-2017 01:57 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you asked Jio about this? Have you checked to make sure the APN settings are correct?
    10-04-2017 04:51 PM
  1. Why are my Bluetooth headphones only connected for call audio but not media?
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 12-31-2019, 12:07 PM
  2. nextbit robin screen wont turn and not charging....
    By Go Techie in forum Nextbit Robin
    Last Post: 10-13-2017, 08:13 AM
  3. Why am I not able to connect my Samsung device with the jbl speaker?
    Last Post: 10-04-2017, 04:56 PM
  4. Factory reset
    Last Post: 10-04-2017, 04:54 AM
  5. Replies: 1
    Last Post: 10-04-2017, 04:29 AM
