    My son has a note 4 that I carried over from Verizon to ATT. It has multiple system updates available. When I go thru the setting to check for updates, it shows they're available. When I click update, it comes up with an error and to check back later. I've checked back for many months & the same answer shows up. It will not update. My other son has a note 4 from ATT & it has updated several times. Why does the note 4 from Verizon not update but the ATT note 4 update. We have our cellular service thru ATT. I contacted ATT & about the Verizon Note 4 & they explain it doesn't have anything to do with them. That is it the phone itself. How do I correct this besides getting another phone for them? I'm not looking forward to a higher cell phone bill then what we're already paying. Any & all suggestions would be appreciated. TIA.
    10-14-2017 12:50 PM
  2. Rukbat's Avatar
    The one that doesn't update has the Verizon firmware in it, and AT&T doesn't send Verizon updates. Verizon doesn't update phones that aren't registered to them. Moving a phone off the network it's made for (say even moving from Verizon to using Verizon towers with Straight Talk) eliminates updates. That's just a fact of life.
    10-14-2017 03:20 PM
  1. How do I get my play store back to my phone
    Last Post: 01-25-2018, 12:19 AM
  2. GEAR S3 Classic LTE won't give me a sync code
    By Honey_184 in forum Samsung Gear S3
    Last Post: 01-16-2018, 10:11 AM
  3. Will the hardware be an upgrade over my 6p?
    By Curtendz in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-15-2017, 12:19 AM
  4. Why is my Note 5 volume adjusting itself to minimum?
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 10-14-2017, 04:57 PM
  5. verizon phone for tmobile network
    Last Post: 10-14-2017, 12:27 PM
