    Help!! Detailed instructions how to install OS on Amp Prime to unlock it. Please help me. I want to learn.
    10-18-2017 02:48 PM
  2. Rukbat's Avatar
    Unlock the SIM lock? Or unlock the lock screen?
    For the first, if you live in the US, search your-carrier unlock. Each of the carriers has a web page with instructions to get it. (It normally takes a couple of days before you get an email with the code.) If you don't live in the US, installing an OS won't unlock it.
    For the second, you have to remember the unlock password or PIN - you can reset it at Android Device Manager.
    10-18-2017 04:05 PM
  1. Navigation keeps minimizing to the home screen
    By tpd15 in forum Google Pixel & Pixel XL
    Last Post: 01-31-2019, 08:53 PM
  2. Sending mp3 file stored on my phone via Whatsapp
    Last Post: 10-18-2017, 04:51 PM
  3. Why can't I use mobile data on my LG G6?
    Last Post: 10-18-2017, 03:57 PM
  4. S6 phone randomly changed the current time to one hour behind.
    Last Post: 10-18-2017, 02:01 PM
