1. Lageter's Avatar
    My Lg stylo 3 plus as a problem connection problem on any bluetooh device.
    10-19-2017 11:47 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does the phone detect any nearby Bluetooth device? Are you sure you're going through the pairing process correctly? On the phone, go to the Settings>Bluetooth menu, tap Menu, and tap Refresh or Scan to make sure it's actively looking for a device. On the Bluetooth device, make sure you're following the correct steps to initiate pairing -- often by pressing and holding a Connect button for about 3 seconds.
    10-21-2017 01:40 PM
  1. multiple bluetooth problems with S8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 10-19-2017, 10:13 PM
  2. multiple bluetooth problems with S8
  3. Signal messages not being sent-Lg g6
    By Nunya Biz1 in forum Legacy Android & Other OS's
    Last Post: 10-19-2017, 09:56 PM
  4. Replies: 1
    Last Post: 10-19-2017, 09:51 PM
  5. Updating problems with my samsung galaxy s5
    Last Post: 10-19-2017, 08:32 PM
