    my letv battery drains after 5% only, after that 5,4,3,2,1,0 shutdown immediately after every second count?Hlep to solve this issue
    10-20-2017 08:25 AM
  2. belodion's Avatar
    Don't discharge so much. Recharge at about 40%.
    10-20-2017 09:03 AM
  3. Rukbat's Avatar
    And if you've been discharging it down to 5% for a while, you may have damaged the battery, and have to replace it. (Lithium batteries are not deep-discharge batteries.)
    10-20-2017 10:58 AM
  1. My huawei p8 lite is consuming battery even if its turned off.
    Last Post: 10-20-2017, 12:20 PM
  2. Unusual problem. Nexus 5 does not recognise the battery
    Last Post: 10-20-2017, 11:37 AM
  3. Bluetooth issues after Nougat
    Last Post: 10-20-2017, 05:46 AM
  4. battery changing with 3 pin
    Last Post: 10-20-2017, 01:57 AM
  5. Rounded Corners On Battery Icon In Commercials
    By svenEDGE in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-19-2017, 10:02 PM
