    cant use my apps wont let me charge but can get calls in .
    10-20-2017 08:43 AM
  2. Rukbat's Avatar
    Unfortunately, you can't replace the battery in the S6 by yourself, so it's going to have to go into a repair shop. (If it's a really well-equipped shop, they may be able to recharge the battery once they remove it - it probably needs to be pre-charged first, which the phone won't do) - otherwise they'll have to replace it.
    It sounds as if you let the battery get too low before you recharge it, on a regular basis. Never let it get below 40%. When it gets down to 40%, either recharge t or turn the phone off. Lithium batteries are not deep-discharge batteries. A month of draining the battery to almost 0 before recharging it will kill it.
    Laura Knotek likes this.
    10-20-2017 11:22 AM
  1. SOLVED: Why Did the Color of My Notification Bar and Navigation Bar Change?
    By Father Tech in forum Legacy Android & Other OS's
    Last Post: 07-16-2018, 01:38 PM
  2. Z2 Force battery with battery mod
    By jademps64 in forum Moto Z
    Last Post: 12-19-2017, 10:10 AM
  3. Unusual problem. Nexus 5 does not recognise the battery
    Last Post: 10-20-2017, 11:37 AM
  4. How to silence System sounds at device ON, OFF, and other system events
    Last Post: 10-20-2017, 11:33 AM
  5. battery drain after 5% discharge
    Last Post: 10-20-2017, 10:58 AM
