    my new s8+only bought last week was stuck and noy responsive sometimes when baterry is less than 20% . everytime when the bateery is less than20% the phone is be behaving crazy and very slow . what could be the reason
    10-25-2017 01:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is a power-saving mode automatically turning on at that level? If so, see what happens if you turn that off.
    10-25-2017 01:15 AM
  3. hanzal nazar's Avatar
    But my phone get stuck and hang..its very slow and unresponsive ehn getting to 20 % or below
    Anybody have remedies.its my new phone only 10 days
    How to turn this off
    10-25-2017 03:18 AM
  4. B. Diddy's Avatar
    Thanks for registering. You didn't actually answer my question, though -- is there a power-saving mode that is automatically turning on when the battery reaches 20%? If so, then perhaps it's throttling down the processor, leading to sluggish performance.
    10-25-2017 03:28 AM
  5. hanzal nazar's Avatar
    I didnt turn on my low battery mode..its turned off.
    I dont know if it turnig on automatically or not..how to check that
    You are correct.the exact word is sluggish performance.. how is this possible
    Samaung is not reeponding to my question
    10-25-2017 03:33 AM
  6. chanchan05's Avatar
    You could take it back and ask for a replacement. It's only 10 days old anyway.
    10-25-2017 03:39 AM
  7. hanzal nazar's Avatar
    I am a frequent traveller and now am in another country..i bought from dubai
    10-25-2017 04:12 AM
  8. chanchan05's Avatar
    What Android version are you on? Have you updated?
    10-25-2017 04:52 AM
  9. hanzal nazar's Avatar
    Its with the factory settings..i havent updated anything
    10-25-2017 02:03 PM
  10. B. Diddy's Avatar
    Does this also happen in Safe Mode? https://support.t-mobile.com/docs/DOC-34283
    Also, to make sure you have a genuine S8+ (and not a knockoff), install CPU-Z and make sure the phone's CPU is made by either Qualcomm or Samsung. If it's anything else (like MediaTek), it's a fake.
    10-25-2017 02:03 PM
  11. hanzal nazar's Avatar
    Samsung exynos octa 8895 2.31 ghz
    10-26-2017 02:37 AM
  1. Battery not lasting as long as others. How do I fix it?
    Last Post: 10-25-2017, 01:24 AM
  2. galaxy s 5 mobile. how do i locate trashed text message contense
    Last Post: 10-25-2017, 01:19 AM
  3. headset and speaker problem
    Last Post: 10-25-2017, 01:18 AM
  4. why is my storage so low
    Last Post: 10-25-2017, 01:17 AM
  5. Motto Game pad mod and Retro Arch?
    Last Post: 10-24-2017, 10:45 PM
