    I have a very strange issue, and not certain it is related to other issues with Bluetooth Nougat and bluetooth.
    Issue:
    Have a Jabra Halo Smart, the device connects perfectly to the phone, and other than the occasional choppy sounds, works like a dream. However, when using Skype the first time, it will work with Skype (Test service/echo), then at some point later, when I make a Skype call, I will hear the beeps of trying to set up connection, but the ringing and the call it self will use the handset.
    In Hangouts calls it will just use the handset.
    However, if it works or not, it will still pause the music playing. Before and after the issue, phone calls will use the headset correctly, and the music player (Apple Music, Youtube, Spotify) all acts as it should.
    I can reset and get Skype working again, by unparing the headset in android, restart the phone and reset the bluethooth device completely. But the issue will return.
    I have also tried the fix of reseting all network settings, but that was only a temporary fix.
    Phone:
    Samsung Galaxy S7 Edge
    Android 7.0
    10-25-2017 05:09 AM
  1. Replies: 1
    Last Post: 10-26-2017, 03:42 AM
  2. galaxy s8+ slow and stuck and hanging when battery is less than 20%
    Last Post: 10-26-2017, 02:37 AM
  3. samsung s8+ slow at low battery and getting stuck why??
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 10-26-2017, 12:04 AM
  4. Phone starts rebooting and crashing google apps.
    Last Post: 10-25-2017, 07:39 AM
  5. headset and speaker problem
    Last Post: 10-25-2017, 01:18 AM
