    While using youtube i loose 1% battery in 6 min and while talking with internet on it takes around 13 min to discharge 1% so, in whatsapp use it takes around 7 min to discharge 1 % is it ok for the 3000mAh battery
    10-25-2017 09:43 AM
  2. Javier P's Avatar
    Welcome to the forums. Battery use depends on many factors: WiFi/mobile data, cell signal, screen brightness, sensors enabled, etc. It's impossible to establish a 'normal' rate of discharge, but looking at your numbers they look fine.
    10-25-2017 10:00 AM
  3. Rukbat's Avatar
    But you should never allow the battery to drop below 40% - any lithium battery. (Lithium batteries are not deep discharge batteries.) Letting it drop to 1% all the time will kill the battery in a few months. Either charge it at 40%, use a power pack when it gets down to 40% or turn it off.
    10-25-2017 12:07 PM
  1. Note 8, Android Auto, and Amazon Music Issue
    By Graphixx30 in forum Samsung Galaxy Note 8
    Last Post: 11-29-2017, 12:28 AM
  2. Anyone else not getting their devices shipped in the last couple days?
    By jessesmith8888 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-26-2017, 07:54 PM
  3. How to disable the most frequent used apps in android steriods
    Last Post: 10-26-2017, 04:35 AM
  4. Having issues with my accessing my email
    Last Post: 10-25-2017, 12:09 PM
  5. Battery draining fast. Where to get replacement battery in or around Delhi?
    Last Post: 10-25-2017, 08:18 AM
