how to re enable required permissions for adding contacts on zte blade zmax
  • Start date Start date
A
Android Central Question
I accidentally disabled them not knowing they where required
Welcome to Android Central! Go to Settings>Apps, tap Menu>Show System, select Contacts, then Permissions, and make sure all permissions are turned on.
I can't add contact because somehow I have disabled permission and I don't seem to have a menu key even following your response to another user.. ZTE Z3001s
I am a first time smartphone used
Welcome to Android Central! The Menu button is the one that looks like 3 vertical dots in the corner of the screen.
Nienna
