    Hi,
    My problem is the following: lately my phone won't load certain webpages& Pinterest, and won't send photos via Viber when I am using wifi connection. It works perfectly with 4G, but with wifi it simply doesn't. My husband has no problem with any of the above on his LG. Any suggestions? (The phone was bought 3 months ago and worked without a problem with the same connection for 2 months)
    Thank you in advance!
    10-31-2017 12:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this only happen on one particular wi-fi network, or on any wi-fi network?
    11-01-2017 03:20 PM
  3. DMJDMJ's Avatar
    Hi,
    Original poster here. Thank you for your help! I had a chance to check it on three other wifi networks - my phone works perfectly with all of them.
    This might be a slightly idiotic question on my part 0.0 but could this problem be related in any way to the fact that I hardly seem to have normal cellular signal strength at home?The most I ever have is the two smallest bars in the triangle.
    11-04-2017 07:16 AM
  4. B. Diddy's Avatar
    Poor cell signal shouldn't affect wi-fi. First, try rebooting your router by unplugging its power for about 10 seconds. If that doesn't help, then you could try logging into the router's settings via your computer browser (see the router manual to learn how), and disable IPv6 there.
    11-04-2017 06:32 PM
  1. Problem with Casting Amazon Prime and Netflix
    By B Hoste in forum Samsung Galaxy Note 8
    Last Post: 09-23-2018, 08:10 PM
  2. will my samsung neo 2 charger work for my samsung s
    Last Post: 11-01-2017, 03:22 PM
  3. How do you get rid of unsaved numbers on a jet 3 Samsung?
  4. CSC change on Samsung A5 SM-A520F
    Last Post: 10-31-2017, 12:00 PM
  5. Replies: 3
    Last Post: 10-31-2017, 11:58 AM
