    I am trying to connect blutooth wireless ear phone . It couldn't discover to connect and it keep turning the bluetooth on and off by itself.
    11-03-2017 07:30 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which Galaxy Note phone do you have? Which Bluetooth is turning on and off -- the phone's or the earpiece's? Are you sure you're following the correct steps to pair, as described in the earpiece's manual? Do you have to press and hold a Connect button for about 3 seconds first, to initiate the pairing process?
    11-03-2017 08:33 PM
  1. Note 4 major performance issues
    By Nick_1020 in forum Samsung Galaxy Note 4
    Last Post: 12-06-2017, 07:13 PM
  2. Wireless charger stand
    By Jax112 in forum Samsung Galaxy Note 8
    Last Post: 11-07-2017, 10:40 AM
  3. Update flash player pop up will not go away from my home screen
    By Mrpoopybuttho in forum Ask a Question
    Last Post: 11-04-2017, 06:08 PM
  4. Replies: 2
    Last Post: 11-03-2017, 08:52 PM
  5. Replies: 1
    Last Post: 11-03-2017, 08:47 PM
