1. Shamrock97's Avatar
    Hi. Since the recent upgrade my Nexus 5x is double bleeping every couple of minutes (unless on do not disturb setting). I have turned off NFC and can't find the notification reminder option in settings. This is slowly driving me potty. Any suggestions gratefully received. Thanks
    11-05-2017 11:47 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen in Safe Mode as well? https://support.google.com/nexus/answer/2852139?hl=en
    11-05-2017 10:36 PM
  3. Shamrock97's Avatar
    Thank you! I have just tried safe mode and no, it doesn't seem to happen. I'm now back to normal mode and the double bleeping has started, arrgghhh!
    11-07-2017 12:28 PM
  4. B. Diddy's Avatar
    Unless anyone else here recognizes this issue, you may just have to uninstall apps one by one until the beeping goes away. Start with your most recently installed apps.
    11-07-2017 08:59 PM
  5. Shamrock97's Avatar
    I was hoping to avoid that but think I'm going to have to try it! Thank you
    11-09-2017 11:27 AM
  1. Is your Snapdragon S8/S8+ Behind on Security Updates?
    By mtwalther in forum Samsung Galaxy S8 & S8+
    Last Post: 03-07-2018, 07:23 AM
  2. Can't find/setup contact favorites, any help appreciated.
    By Digihorizons in forum Samsung Galaxy Note 8
    Last Post: 11-11-2017, 10:29 PM
  3. Samsung apps (like Samsung Notes) on other devices (like a PC)
    By dlalonde in forum Samsung Galaxy S8 & S8+
    Last Post: 11-07-2017, 06:01 AM
  4. Floating msg icon, please help!!!
    Last Post: 11-05-2017, 10:42 PM
  5. Replies: 1
    Last Post: 11-05-2017, 10:21 AM
