    I had my phone charged all day I used it for a few minutes and the battery was on 97% then all of a sudden my phone turns off and then restarts and my battery is on 3% I would like to know what could have happened I have a Samsung galaxy s5 .
    11-09-2017 11:44 PM
  2. Zulfigar's Avatar
    Might be your battery going (or went) bad. See if you can get a replacement and if that fixes your issue.
    Though, sometimes, just taking it out and putting it back in also helps.
    11-10-2017 03:26 AM
  1. Strange battery drop?
    By dougdraws in forum Samsung Galaxy Note 5
    Last Post: 11-15-2017, 12:35 PM
  2. Not getting sms when hide sensitive information is on
    Last Post: 11-11-2017, 09:52 PM
  3. battery problems
    Last Post: 11-10-2017, 07:37 AM
  4. Why my phone is compatible for apps?
    Last Post: 11-09-2017, 11:56 PM
  5. How can i get my gifs to play on a continuous loop when i send them?
    Last Post: 11-09-2017, 11:32 PM
