What else can I do to reduce battery drain
  • Start date Start date
A
Android Central Question
Even while plugged in and charging, on the charger I got with it from the store, with screen on minimum, auto brightness turned off, though the screen still seem to brighten a little over time, and in safe mode, my LG not only won't it charge it lose but will loss power and only seem to charge with any reliability when off and then it takes a hours to do so for maybe an half hour charge
ameliadinkins
