    I've rebooted the phone factory reset it and it still won't connect to the wifi I don't know what to do
    11-11-2017 10:23 AM
  2. Morty2264's Avatar
    Welcome to the forums! My phone sometimes encounters problems connecting to WiFi. Can you find your desired network on your phone when you go to your network connections tab in your Settings app? Do you need to input your password? Do any other phones in your household have any problems connecting to the WiFi?
    Maybe try resetting your WiFi connection and see what happens. I do this when my WiFi is giving me trouble.
    11-11-2017 10:44 AM
  1. will 600 level the playing field?
    By thecaddyman in forum T-Mobile
    Last Post: 01-04-2018, 11:07 AM
  2. When i tap on my gallery i cant see or delete any of my pictures.
    Last Post: 11-11-2017, 01:23 PM
  3. I cant move my apps to my sd card.
    Last Post: 11-11-2017, 10:32 AM
  4. My Xperia Z5 Compact doesnt charge and restarts the screen
    Last Post: 11-11-2017, 10:29 AM
  5. I think my cellular radio got turned off?
    By messypotamia in forum Essential Phone
    Last Post: 11-11-2017, 09:47 AM
