    I have tried all the suggestions I read in the internet and spent lots of time figuring it out, but still, nothing happened. Please help.
    11-11-2017 09:06 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It'd help to get more details about the problem, and also to know what you've tried. Is this the stock messaging app? Are you getting notification icons in the status bar, just without any audible tone? Is your Ringtone/Notification volume slider turned up? Are the Notification settings in both the System Settings and in the Messaging app's settings correct?
    11-11-2017 11:47 PM
  3. KatyaPerry's Avatar
    I have the same problem. I hope someone can answer this for us... help
    01-08-2018 11:08 PM
  4. JCeladina's Avatar
    go to settings >> apps >> messages >> notifications... disable "show silently"
    belodion likes this.
    02-08-2018 11:39 PM
  5. Mthandazo Dube's Avatar
    I also have the same problem. I have also tried everything but no avail. It has nothing to do with the settings. I think Samsung should fix it and send us an update.
    04-15-2018 11:27 AM
  6. Jenna2018's Avatar
    I had the same problem and now its fixed go to the settings - apps - tap apps - scroll until you see Whassap - then tap whassap and you will scroll down to apps setting - and tap on allow notification. hope that help
    06-27-2018 04:26 AM
  1. Locked my sim on an unlocked version
    Last Post: 11-11-2017, 11:58 PM
  2. Is there a way to unlock my phone using a computer?
    Last Post: 11-11-2017, 11:51 PM
  3. My S7 Phone keeps shutting off and heating up
    Last Post: 11-11-2017, 11:50 PM
  4. My icons will not drag. How do i move them
    Last Post: 11-11-2017, 09:56 PM
  5. Replies: 1
    Last Post: 11-11-2017, 09:19 PM
