    Most of these question are old, but I am having a problem with the battery draining in like 9 hours without even using the phone. I bought a new battery about 2 months ago when I had this problem and now I have it again with the new battery. When I go to settings and look under battery it says Google Play Services is using 87%. I do not use my phone for anything exept phone calls and text message and sometimes not even for a couple of days in a row. Once in a great while take a picture. Fully charged this morning and now says I have only 1 hour, 6 minutes and 55 seconds left.
    11-12-2017 07:50 AM
  2. belodion's Avatar
    🙋 Do you have Location set to high accuracy or anything like that? One possibility is that an app is requesting location repeatedly. Try Safe Mode and tell us whether that stops the drain. It may be nothing to do with Location, but what happens in Safe Mode will help in the diagnosis.
    11-12-2017 08:12 AM
  1. Replies: 5
    Last Post: 12-29-2017, 09:35 AM
  2. Why is my android phone shouting down apps
    Last Post: 11-12-2017, 10:06 AM
  3. Replies: 1
    Last Post: 11-12-2017, 10:02 AM
  4. my Pixel2 goes to sleep in ten seconds, regardless of setting. Very annoying
    Last Post: 11-12-2017, 07:48 AM
  5. Replies: 1
    Last Post: 11-12-2017, 07:36 AM
