    Hello, I am planning to purchase infinix note 4 pro but I am confused regarding its speed. Can anyone please tell me if it is a good phone with good speed or not? I mean its has 1.3ghz processor with 3gb ram and as far as I got to know after googling it, it said its not enough for a good speed cellphone. I am so confused. I dont multi task or anything and my use will be not much so I dont care if it has very fast speed as long as it doesn't get stuck or anything like that. Plus, I want to ask the same exact question regarding qmobile noir e2
    11-12-2017 10:56 AM
  2. Rukbat's Avatar
    The Samsung Note 3 runs at 1.9GHz, which isn't all that much faster than the Infinix, but the Infinix is a much newer phone. I don't think you'll have any problem running non-gaming apps, as long as you remember to Back out of am app, not press Home to get out of it (which leaves it running, taking up space and time). A lot of people make that mistake, even on faster phones, then complain about how slow they are.
    11-12-2017 12:04 PM
  1. Replies: 2
    Last Post: 11-26-2017, 10:34 PM
  2. Using gps and music apps simultaneously
    By jakewoodblues in forum Ask a Question
    Last Post: 11-12-2017, 12:49 PM
  3. I switched to messenger and now I can't. Find my contacts
    Last Post: 11-12-2017, 12:40 PM
  4. Replies: 1
    Last Post: 11-12-2017, 12:28 PM
