    I discovered while filming a video using my selfie camera on my Galaxy S6 that if I turn the camera away from my face and then return to it, those moments during which my face was not visible to the camera somehow get out of sync with the audio, creating a lag when the camera returns to my face. Its as if the camera is using facial recognition to sync the audio to my face but as soon as a face is not visible for the camera to use as a reference it totally abandons all semblance of reason and decides to add a second long delay that increases periodically every time you turn the camera away from your face. By the end of the video I used to test this, the lag was so bad that by the time the audio starts to play, the video file is already several seconds ahead. Why? Help?
    11-14-2017 10:53 AM
  1. Anyone else receiving a an update?
    By Mikey88Chaos in forum LG V20
    Last Post: 12-06-2017, 07:57 PM
  2. Crupted file after update android
    Last Post: 11-14-2017, 11:26 AM
  3. Buy a new phone get an old operating systems
    Last Post: 11-14-2017, 11:23 AM
  4. why am i receiving duplicate text on my samsung galaxy s8 plus?
    Last Post: 11-14-2017, 10:38 AM
