I have a Brightness Issue with my Galaxy S7 Edge π, The Auto Brightness is turned off but the screen dims, I use Manual Brightness to the maximum but it doesn't allow me to keep it, π₯
and if i flash a light on the sensor (or use it in the sun) it becomes brighter, I don't want that.. it's like Auto Brightness. I want to use Manual Brightness at maximum, Or if there's a trick to use Auto Brightness at maximum and keep it like Manual Brightness not changing that would be better (Because it's brighter than Manual) π, I don't care about Battery Life.. π I want to use the maximum brightness possible and not have it changed by itself βΊοΈ
I read on xda-developers.com that you need root + deodexed rom to replace services.jar
I know how to root, But what is deodexed rom? π°π§
Can anyone here help me? π I would really appreciate it π€
11-14-2017 11:04 PM
