    Hi. My Samsung tablet 4 is not showing any sign of an incoming call but is always ringing. But sometimes it will display an incoming call. I mean sometimes there won't be an actual incoming call and still keeps on ringing. Also my battery is dying out much faster than before. Can you help me with these problems?
    11-19-2017 01:21 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device? Is it a Note 4? I'm assuming it's a phone and not a tablet if you're getting an incoming call.
    Does that ringing still happen if you turn off NFC?
    For the battery, it would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    11-19-2017 02:46 AM
  1. how can we remove the privacy and app encryption password while forgetting?
    Last Post: 03-30-2020, 07:00 PM
  2. Replies: 1
    Last Post: 11-19-2017, 08:56 AM
  3. Can't find cause of excess battery drain
    Last Post: 11-19-2017, 02:52 AM
  4. Phone opening apps/files by itself?
    Last Post: 11-19-2017, 02:49 AM
