    even i brought new battery after inquring from service center and i have also checked the battery charger
    pls help me
    11-25-2017 09:21 AM
  2. belodion's Avatar
    🙋 A bad charging lead? A bad USB port? Something else Internal?
    11-25-2017 12:07 PM
  3. Rukbat's Avatar
    You can be running enough apps at one time to be using more current than the phone can draw from the charger (that's determined by the phone, not by the charger), so the rest of the current comes from the battery.
    Tap "last used apps" and wipe them all off - that closes them. In the future, use the back button when you're done using an app, not the home button. Using the home button leave the app running in the background.
    11-25-2017 02:33 PM
  1. Samsung Galaxy Tab A slow charging after system update
    By IMHughes in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 03-20-2018, 07:54 PM
  2. Why is Samsung Galaxy Tab A using 14.8 GB for system data
    Last Post: 11-26-2017, 12:12 AM
  3. Replies: 2
    Last Post: 11-25-2017, 02:34 PM
  4. Can I add LastPass instead of 'Autofill with Google' as my autofill service?
    Last Post: 11-25-2017, 12:10 PM
  5. why is my mobile data oning automatically
    Last Post: 11-25-2017, 12:09 PM
