    I noticed this when the LTE was first activated so after getting tired of little to no signal, I went into the secret menu and switched off the LTE and went back to HSPDA and now have 3-5 bars all the time in the same locations. Internet speed has not affected much. Signal strength is -102 dbm on LTE but it is -79 dbm on HSPDA at the same location. The tower is 1.2 miles away and supports both LTE and 3G and HSPDA.
    11-29-2017 09:01 PM
  2. BB-JAM215's Avatar
    Has this "issue" affected the actual performance of your phone in any way?
    You may find that even with a low LTE signal your phone will automatically switch to HSPDAZ as soon as you make a call.
    Of course, if it does work better with LTE off then that would be your best option.
    11-29-2017 10:26 PM
  3. Rukbat's Avatar
    You asked if anyone else noticed it. That would depend on your location. Someone in your city might if they were near you, because you may be in a partial dead spot for band 4 or band 17, whichever one they're using where you are. (It can be as simple as what's called "knife-edge refraction" causing the signal to skip over you, and it's highly frequency dependent.
    I find about -97 to -101 db from AT&T where I am on band 17, and never had a problem downloading.
    11-30-2017 05:17 PM
  1. Anyone else have the Facebook nav bar suddenly move to the bottom?
    By ABOSWORTH007 in forum Samsung Galaxy S8 & S8+
    Last Post: 12-03-2017, 08:47 AM
  2. Will a Samsung galaxy tab a 10.1 fit with the Samsung galaxy tab 3 10.1 case?
    Last Post: 12-01-2017, 12:48 AM
  3. Is honor 6x the onky 3gb ram phone?
    By mcsambo in forum Honor 6X
    Last Post: 11-30-2017, 09:16 PM
  4. why is my lg home button lighting up but the phone wont turn on
    Last Post: 11-30-2017, 05:36 AM
