    I plug in my headset and the volume automatically become silent mode, this also happen at music volume. Besides that, the sound control notification keeps appear and blocking my view. I'm using Huawei P7 Prime now, why do these happen ? Is there any solutions?
    12-02-2017 09:30 AM
  2. Rukbat's Avatar
    Just turn the music volume up to where you need it, and the notification should stop. The reason for it is that if the volume is all the way up and the headset is in your ears when you plug it in, you could lose a large part of your hearing - from just a single crescendo. You're supposed to turn the volume down before using the headset, but a lot of people don't - then complain about hearing loss, so if the volume is off, that can't happen.
    (And it's not just rumor and nonsense - I lost most of my hearing in one ear when I was holding a two-way radio to it, and there was a very loud static crash. And it's a permanent loss. I now have to wear hearing aids.)
    12-02-2017 12:28 PM
  1. Wi-fi and blue tooth unable to connect on my Samsung Tab s
    Last Post: 12-02-2017, 07:17 PM
  2. not able to start my phone
    Last Post: 12-02-2017, 01:55 PM
  3. Replies: 1
    Last Post: 12-02-2017, 01:53 PM
  4. Why is my apps storage is high?
    By Khadkas in forum Android Apps
    Last Post: 12-02-2017, 09:57 AM
  5. Why my earphones doesn't work during calls ?
    Last Post: 12-02-2017, 09:10 AM
