    Does the galaxy note 8 phone automatically stop charging or go into trickle charge mode after reaching 100% charge
    12-04-2017 08:57 PM
  2. Rukbat's Avatar
    Yes - if the phone is working properly, the charge will stop at 100%. The indicator that it's charging will remain, but no current will be pushed into the battery until the battery voltage drops a little (if the phone is on), Then the battery gets topped off.
    12-04-2017 11:38 PM
  1. Why can't I view my photos?
    Last Post: 12-05-2017, 01:34 AM
  2. How do I know if Authorities are monitoring my device?
    Last Post: 12-04-2017, 11:43 PM
  3. How to update MOTO smart phone system without WIFI
    Last Post: 12-04-2017, 10:54 PM
  4. My phone is mute and i restarted it and all the volume is gone how do i fix it
    Last Post: 12-04-2017, 10:47 PM
  5. Replies: 0
    Last Post: 12-04-2017, 07:43 PM
