    This has only happened in the last 4 months.
    12-05-2017 05:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    12-06-2017 12:21 AM
  1. Music sound lowers whens Google Maps talking and is stuck at lower volume now.
    Last Post: 10-30-2018, 08:13 PM
  2. Low battery temperature
    By Philip Brown3 in forum Nokia 6
    Last Post: 12-06-2017, 05:26 AM
  3. How do i recover my pass code for my private photoes
    Last Post: 12-06-2017, 12:24 AM
  4. i forgot my hidden's pattern password...how can i do to open my hidden's app
  5. What is the black dot on my S2 watch?
    Last Post: 12-05-2017, 05:22 PM
