A
Sounds like there's some rogue app using the battery excessively. Are you able to view which apps are using your battery and see if one is excessive? Otherwise go in to safe mode and see if it persist.
Very interesting. The Next Step I would recommend is putting the phone in Safe Mode and then taking another screenshot after an hour or so and see if that slows down the battery depletion.
It's a little better... But not much. I messaged a frequent user and hopefully he/she can help.
