Originally Posted by
chanchan05 Use Samsung's Sound Assistant app from the Play Store. It allows you to have a second volume slider to lower the volume even more.
I do find your case weird because volume goes down to zero, which means no sound is playing. Where are you achieving this 'lowest setting' that still has sound?
Screenshots would be ideal.
My volume is currently at 1% of full volume. I achieved this through the Precise Volume app (seen in the screenshot below)
In addition, I have set all the frequencies to -10dB in the built-in android equalizer:
What the volume sliders look like. They look like they are on 5%, but Precise Volume overrides this, so they are actually at 1%.
And Sound Assistant (Thanks for the tip. Currently not at the lowest setting, but as my phone keeps getting louder it soon will be):
