    I have had my Galaxy Gear S3 for about 4 months and except for the second day it has been running perfectly. The second day I had it I ended up having to factory reset it because it was loosing 1% a minute in battery. After I reset it and set it up the same way it would last me about 4 days. That's how it has been since then until yesterday. Now it doesn't last me a full day. In 3 hours it has lost 20% battery which is what it would use on a normal 12 hour day. I really don't want to have to factory reset this every few months due to unexplained rapid battery drain. Has anyone else experienced this?
    12-08-2017 12:00 PM
  2. belodion's Avatar
    Would you like me to move this to the Gear S3 forum so that you can engage directly with other users there?
    12-08-2017 01:29 PM
  1. Verizon 2XL on AT&T, Anyone?
    By tsquare2112 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 04-08-2018, 08:54 PM
  2. Verizon Galaxy S8 Audioserver suddenly causing massive battery drain
    By gsilver0 in forum Samsung Galaxy S8 & S8+
    Last Post: 12-13-2017, 12:00 PM
  3. SMS not working well on AT&T
    By npnigro in forum Huawei P10 & P10 Plus
    Last Post: 12-08-2017, 02:43 PM
  4. How do I change my profile picture on the messanger app?
    Last Post: 12-08-2017, 12:05 PM
  5. bluetooth headset not working on bluestacks?
    Last Post: 12-08-2017, 11:39 AM
