The battery life wont reduce but then if I turn it off remove the bettery, then put the battery again then turn it on the battery percentage change, it only change when i turn it off
Welcome to Android Central! Which phone? Did you ever replace the battery?
Try using it until the phone shuts off automatically from low battery. Then charge up to 100% again, and see if the battery indicator is more accurate now.
