A
Android Central Question
I have been trying to use a secure VPN.
I've downloaded a secure VPN app and when I open it it allows me to choose a location.
After I have I go to my developer options and when I get to the mock location settings it says that I do not have any set apps, but what I really want to know is why I cannot enable or disable the mock locations setting.
THERE IS NO SLIDE BAR OR WAY TO turn it on.
All it does is allow me to click on it and either set " no app " or set my messages app which seems to do nothing when i select it.
What do I do!?!?
What do I do!?!?
