    My s7 edge isn't fast charging anymore and am using its original charger
    12-19-2017 02:04 PM
  2. Mooncatt's Avatar
    It could be a number of things, but the first place to start is usually the USB cable. Micro-USB cables should never have been adapted to double as a power cable in my opinion because they always went bad on me. Other symptoms are intermittent charging, problems tethering to a computer and data transfers. It's also the cheapest fix.
    So my suggestion is to first replace the USB cable. If that doesn't work, then it could be either the charger itself (rare in my experience), or a bad USB port on the phone (more common than the charger, but a bigger problem to fix).
    12-19-2017 02:52 PM
  3. Rukbat's Avatar
    Or, if you treat the battery the way m any people do (discharging it almost all the way before charging it - it should never get below 40%), it may be time for a new battery.
    12-19-2017 05:09 PM
  1. trying to find out what used com.samsung.android.mtpapplication stands for
    Last Post: 12-20-2017, 12:50 AM
  2. embeded links do not work / can;t access guest wifi web / no guest wifi
    Last Post: 12-20-2017, 12:49 AM
  3. Why my galaxy j500h start restarting
    Last Post: 12-20-2017, 12:46 AM
  4. Losing charge
    Last Post: 12-19-2017, 05:12 PM
  5. I need my punk unlock code for straight talk
    Last Post: 12-19-2017, 01:45 PM
