    My phone is Nexus 6P running under Android 8.1.0.
    In my home there are two WiF sources---a router in one floor and an extender in another. Both have the same access password.
    In the past I could setup the WiFi options so as to 'connect automatically' to at least one of them. Not any more. Now, when I move from one floor to the other, I have to manually connect to the better signal. If I don't, I may loose connection altogether.
    Is there a way to take care of that?
    12-24-2017 05:25 AM
  2. Rukbat's Avatar
    In the advanced settings for WiFi, there should be a "Auto network switch" item. Turn it on. (You may still lose an existing connection to a site if the phone switches access points - or you may not. It depends on how you have them set up.)
    12-24-2017 02:03 PM
  1. How to hide Mesg Preview on Notification Panel
    By Android Central Question in forum Moto Z
    Last Post: 12-29-2017, 02:26 AM
  2. Why is my text messaging not working?
    Last Post: 12-25-2017, 01:55 AM
  3. Why there is no My knox or S secure in my Samsung J7 Prime?
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 12-24-2017, 02:25 PM
  4. Does anyone have the Sim unlock code for an AT&T LG K10?
    Last Post: 12-24-2017, 06:04 AM
  5. how can i stop these messages ,unfortunately Google play stor stop
    Last Post: 12-24-2017, 04:05 AM
