1. NicolasHCMC's Avatar
    Hi all,
    I have a Huawei GR5, 32GB and I am currently dealing with an intern storage problem. Indeed, my device mentions that my phone is full at 97% but when I try to check what are taking place, I can see that my apps, files and firmware take just 18 GB (On my total of 32 GB) of the intern storage. So I really do not know what takes place on my mobile device? Do you have any suggestions about how can I find it? Thanks in advance
    12-30-2017 02:02 AM
  2. belodion's Avatar
    Hi all,
    Welcome.
    I don’t know what would cause that, but you could try this:
    https://r.tapatalk.com/shareLink?sha...2&share_type=t
    12-30-2017 05:41 AM
  3. Rukbat's Avatar
    Apps have data - that's not showing. Android runs in Linux. That's not showing. There's always going to be a difference between the amount of free internal storage the device claims and subtracting all the shown usage from the size of the device's internal storage. (The fact that total storage is shown in GB and individual storage is shown in GiB makes it worse.) Believe the phone when it says that you're using 97% of the phone's capacity.
    12-30-2017 11:45 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Also try DiskUsage to see what exactly is using your internal storage.
    12-30-2017 01:14 PM
  1. All sensor on galaxy s6 not working
    By Faleradx in forum Samsung Galaxy S6
    Last Post: 01-01-2018, 05:56 PM
  2. Why is my galaxy s3 not charging sometimes?
    By ld5596 in forum Ask a Question
    Last Post: 12-31-2017, 12:24 PM
  3. my phone is on a white svreen with the google symbol on it for the whole day
    Last Post: 12-30-2017, 01:25 PM
  4. Display HDMI input on my phone
    Last Post: 12-30-2017, 06:41 AM
