    I've just got a new new charger dock stand, and my plan was to use it as an easy way to connect my phone (Huawei Mate 9 lite) to the PC. However, everytime I connect my phone, its screen block showing a different wallpaper and the ****, without being able to use the phone till I disconnect it. I try using another phone or tablet and there is no problem at all. Also I try my Huawei with a simple usb cable and it works perfect. What can I do?
    12-30-2017 06:06 PM
  1. s7 edge battery life and bluetooth headphones
    By madman x in forum Samsung Galaxy S7 edge
    Last Post: 01-06-2018, 03:18 PM
  2. How to set the countdown timer to minutes and seconds?
    Last Post: 12-31-2017, 12:28 AM
  3. Samsung tab 4 10.1 with power issues.
    Last Post: 12-30-2017, 10:27 PM
  4. LG G5 battery problems
    By brianmccuk in forum Ask a Question
    Last Post: 12-30-2017, 10:03 PM
  5. Huawei not seeing S7 hotspot
    Last Post: 12-30-2017, 02:16 PM
