Is there a remote microphone that works with the Pixel 2?
patrick_0ne
3
I'm looking for a microphone that I can clip on to my quiet talking offspring so that she can be heard when I'm recording a video of her. Does such a thing exist for Android phones? I would prefer Bluetooth, but it's not a must-have.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Wireless mics use their own radio system, not Bluetooth. But any remote mic system that has a 3.5mm plug, or can use interchangeable output cables (so you can get one with a 3.5mm plug) will work if the plug is wired correctly. Look on Amazon for wireless microphone for android and you'll find many.
You could also use a Bluetooth headset. Some of them are small enough that they can be hidden by a girl's hair.
Phantom3SE
